No. The washers go between the steering knuckle machined surface where the mounting bolts attach to the caliper, and the calipers. So 2 washers total, one for each bolt.I am guessing that you mean you installed 6 of the 5/8" washers between the hub face and the back of the wheel and that gave you the clearance you were not expecting?
I had read some folks run spaces there where you mentioned, so the calipers clear the wheel.
