2000 Silverado ECSB
So using the 2500 bars with stock keys achieves decent lift without bad angles? Did you do extra turns on your keys or did you leave the stock number of threads? How many threads were on your bolts for the keys before and after you started?
MYT HI
wisconsin
Yes they will give some some lift with stock keys. Honestly I couldn't tell you how may threads. We just tightened them so they were about half way in and keys were about in the middle
badazzbulldog
medway,ma
how easy did the old bars come out? did you have to heat the the keys to get the bars out? I have a set of 2500 bars for my 02
MYT HI
wisconsin
One side popped right out with a air hammer and the other needed a little bit of heat and it came right out. I had been soaking them with pb blaster for a couple weeks before the swap
How many threads on each bolt you have now? I believe one of my torsion bars is weaker in my 02 one bolt is slightly more in than the other, a couple of threads
MYT HI
wisconsin
I decided to get a new set of turn signals and searched everywhere for these
Brand new in box apc signals
I wish they were ones with the clear reflector but I will keep my eye out for those
Before
After
MYT HI
wisconsin
Test fitting going on today. Need to totally rework my brackets and shorten some wires
Turns out I need a new inner tie rod along with idler and pitman arms. The plan is to hopefully get GM inner tie rods with the rough country sleeves and moog outers and moog pitman and idler arms.
MYT HI
wisconsin
Got the light bar mounted until I make new brackets. Painted the valance too although I'm not sure how long the paint will stick
I've also been thinking about taking my tow mirrors back off in favor of the stock mirrors
Kkirwan71
I second the removal of the tow mirrors. Color matched stocks would look good
sent from my glade air freshner
Kkirwan71
I really want to have the black sanded down and ptm and chrome caps on the stock mirrors
I plan on doing this Friday with the duplicolor paint. Did you sand down your bumper cap?
MYT HI
wisconsin
New to me wheels. I'm not sure how I feel about them but I needed wheels to put my new dynapros on. Stock 16s are fugly and this is what we had at the farm. I need to polish them and get new lug nuts yet. It should look pretty good IMO
MYT HI
wisconsin
Got some goodies on the way. Need to get pitman and idler arms also
MYT HI
wisconsin
What brand? I'm overdue for some on my 05
Ac delco inner so I can use the rough country sleeves and moog outers. But I'm kinda worried about the moog parts because I heard their quality is going down hill
