GMC4x4
Got it up on jack stands today to determine where a popping/clunking noise was coming from. Looks like my pitman and idler arm are trashed. Then I cranked the torsion bars a little to get my front right tire to stop rubbing in reverse.
GMC4x4
GMC4x4
It's at the shop getting the pitman arm and idler arm replaced along with an alignment.
GMC4x4
Was the steering loose?
It was a little lose going over bump, didn't instill alot of confidence at speed with those 33x12.5 MT'S. It drives better now but I still have that loud popping noise I've been chasing. Now it's almost constant. The front end mechanic that did the work today said the rest of my front end is nice and tight and that he believes the noise is coming from my rear leaf spring bushings and shackles. I can hear and feel it in the front floorboard though, but I guess I'm feeling it traveling through the frame.
GMC4x4
Could be the steering column making the noise and shaking
Shaking is gone now with the new pitman arm and idler. I'm going to buy a torch and replace the leaf spring bushings with some polyurethane ones and get some new shackles next.
squeaky3
Pontiac Il
Put my downpipe and 4" straight pipe on tonight. Was hoping to get the manifold drilled and tapped for my egt probe and install my edge too but that didnt happen as the bugs were bad.
Heres a teaser of the tip...
Cleaned the carpets in the silver truck, blue truck is enjoying the garage spot I made for it, hopefully gonna get the blue one out for a nice highway run next weekend
Mongothemango
Which one? I currently have 4 . Pulled engine and trans for a swap on the 99 rcsb (Red Race Truck) and did wipers on 01 ecsb a few days ago.
Erki
Alberta, Canada
Developed a coolant leak yesterday on the way to work. Wiped it down and ran it at lunch and best i an guess at the moment is somewhere on the lower part of the radiator. Guess I'll be pulling the rad now and searching.
