All parts fail eventually I'm sure they'll be fine
why do you need the sleeves? the outer theads onto the inner
I'd like one of those escalade wheels and some inner escalade door handles and maybe some outers too lol
HIDs are in
Took Some pictures at my grandparents farm
Got some in the radio. I didn't have enough because 2 were faulty already.
Test fitting going on today. Need to totally rework my brackets and shorten some wires
Turns out I need a new inner tie rod along with idler and pitman arms. The plan is to hopefully get GM inner tie rods with the rough country sleeves and moog outers and moog pitman and idler arms.
Finally got my mirror 100% functioning and wired. All I needed to do was wire a plug from the fuse box to the sensor. Two connector pins at the junkyard and a sensor later it's all installed. I also picked up some painted rear Yukon door handles but I cannot figure out how to get them apart for paint
Here's the sensor hiding behind the grille
Also saw this at the yard and it really had me wondering
Said wheels are secret. They aren't the 2k setup I want either
